'Internal wireless device is set to "Radio off"...
Discussion in 'Lenovo (IBM)' started by Sahle, Feb 10, 2012.
  1. manhattan
    manhattan Scribbler - Standard Member
    179
    ...in BIOS setup or powered off by the hardware switch.'
    I just got my x61t back from the repair shop, and that is the error message that I get when trying to turn my wireless adapter on. However, when I looked in the BIOS, it tells me that it is on.
    Where is this "hardware switch"? Or what is going on here?
  2. ygthb
    ygthb SQA Start-Up Guy
    150
    lower half of the front of the case, below the latch to the right.
  3. manhattan
    179
    Thanks, Hitokiri Battousai!
  4. ygthb
    150
    You are the first to ever pick that up. No prize, but congrats.
  5. LaptopGuru
    LaptopGuru Scribbler - Standard Member
    104
    I was looking at that reply for a while and never figured it out.... this time I saw the avatar... Monday = slow :)
  6. Simon
    Simon Pen Pal - Newbie
    Thanks that's a great help, but maybe not clear enough. To those who did not find it, look at the front narrow dimention of the computer, the one who is facing you, closer to you than the "space" bar. find the latch where the display is locked when you close the computer. Now lift the computer 20 cm up, and just one cm beneath the latch you will find a small lock button, it is probably left if you had this problem - move it to the right and you solved it (on its left marked a small icon of a display, on its right the mark includes an icon of a broadcasting display). Be happy
  7. Scriptable
    Scriptable Pen Pal - Newbie
    54
    Cool, I had never even noticed that! I sometimes plug in an external wireless adapter so I wonder if I should turn it off? The internal one gets quite hot sometimes.
  8. LaptopGuru
    104
    I really don't like the design of this switch. I've never bumped it with the T61p, but I have inadvertantly turned the wireless off at least three times in the last two weeks on the X61t.
  9. Sahle
    Sahle Pen Pal - Newbie
    That helps me a lot. Thank you!
