Interesting issue, bet you will be confused.
Discussion in 'Microsoft Windows 7' started by Kyle Porter, Apr 6, 2009.
  1. Kyle Porter
    1,724
    I have windows 7 build 7068 (64 bit) installed on my hp/ compaq 2710p, and for some reason it has a 3gb limitation EXACTLY like the 32bit version.
    Since a printscreen is worth a thousand words, see below.
    NOTE: System manager says only 3gb running, and i have the 64 bit program files folder.
  2. CalebSchmerge
    CalebSchmerge Woof
    137
    It is interesting. I am curious, though, if this has more to do with an invalid build rather than a true limitation. I 100% doubt that this would be there is the RC or final build.
  3. adam.mt
    960
    Very odd. I take it you've confirmed the machine's hardware fully supports more than 3.x GB RAM (the 32-bit limit)?
    That 'might' be the issue (long shot though) - sometimes fixed with a bios update and sometimes not fixable.
  4. Kyle Porter
    1,724
    My tablet is 64 bit capable, and has run windows 7 64 bit with 4gb of ram before.
    I hope this is a build issue, but thought i would post it to confuse some people :D
  5. primexx
    primexx Scribbler - Standard Member
    197
    if it worked with a previous win7 build then it'll just be a build issue.
  6. leaftye
    4,127
    It'd be funny if Microsoft was just messing with you so you don't try to keep using the beta after the final version is released.
  7. Kyle Porter
    1,724
    For anyone who cares, it was due to a botched installation. Reinstalled that build a little while ago, and it was fixed.
  8. digs_nz
    digs_nz Scribbler - Standard Member
    104
    I wonder whether it truly only used 3gb or actually used 4 and displayed 3 usable! :O
  9. Kyle Porter
    1,724
    System manager reported it was only using 3gb.
