Intel Announces 802.11n Built-in Wireless Card for Tablet PCs
Discussion in 'News Headlines' started by Andrew, Jan 23, 2007.
  1. Andrew
    Andrew Just a Guy Staff Member
    Feb 15, 2004
    289
    <!-- Generated by XStandard version 1.7.1.0 on 2007-01-23T13:18:53 --><p id="firstpara">Intel today announced the 4965 agn wireless Mini PCI card to provide built-in 802.11n for notebooks and Tablet PCs. The 4965agn is an upgrade to the existing 3945abg wireless card shipping with Centrino notebooks. 802.11n will offer faster and greater wireless range.</p>
    The 4965agn card is based on the draft 802.11n Wi-Fi specification. Intel claims the new Wireless-N technology will offer up to five times the performance and twice the wireless range as existing 802.11g wireless. Intel is also claiming this 4965 card will offer greater battery life than notebooks with the existing Centrino 3945abg card.
    [​IMG]<br />Intel 4965agn wireless card that will ship with Vista notebooks (view large image)
    Intel has also announced a program called &quot;Connect with Centrino&quot;. Through this program, Intel has worked with leading access point (AP) vendors including Asus, Belkin, Buffalo, D-Link and Netgear to better ensure compatibility and performance. Intel's wireless-N product is certified to work with multiple APs and as these AP's successfully pass Intel's rigorous real-world testing certification criteria, they will display a &quot;Connect with Centrino&quot; identifier on their product packaging, allowing consumers a choice for connecting with more confidence.
    [​IMG]<br />Intel will be putting this verification sticker on 802.11n wireless router products made by manufacturers such as Netgear that pass the Intel testing for compatibility with the 4965agn wireless card (view large image)
    Having wireless-N technology will improve the home network experience &#8211; especially when multiple people access their wireless network simultaneously to share things such as audio and video entertainment. 802.11n will also reduce &quot;dead spots&quot; in the home. Thankfully, the 802.11n wireless card is backwardly compatible with all older 802.11 a/b/g wireless access points as well, so you won't have to run out and buy a new 802.11n router if your new notebook has this 4965agn wireless card.
    The 4965agn Intel Next-Gen Wireless-N technology as well as the &quot;Connect with Centrino&quot; identifier will be delivered in conjunction with new notebook computers powered by Intel Centrino Duo mobile technology from noteboook makers such as Acer, Asus, Gateway and Toshiba that are being distributed with Microsoft Windows Vista beginning in late January and other manufacturers will follow.
    Here are the specs for the Intel 4965 agn card:
    <ul>
    Dimensions (H x W x D) 2.00 in x 1.18 in x 0.13 in (50.95 mm x 30.00 mm x 3.30 mm)
    Weight 7.2g
    Antenna Interface Connector Hirose U.FL-R-SMT mates with cable connector U.FL-LP-066
    Antenna Diversity On-board diversity support for systems designed with two or three antennas
    Radio ON/OFF Control Supported in both hardware and software
    Connector Interface Mini Card form factor, based on PCIe electrical interface
    LEDs Output Single LED (as per Mini Card specification)
    Operating Temperature 0 to +80° Celsius
    Humidity Non-Operating 50% to 90% RH non-condensing (at temperatures of 25° C to 35° C)
    Operating Systems Microsoft Windows Vista 32/64-bit
    Wi-Fi Alliance Wi-Fi Certified for 802.11a, 802.11b, 802.11g, WMM, WPA, and WPA2
    Microsoft WHQL YES
    IEEE WLAN Standard IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, Draft-N1 (targeting 802.11n when available)<br />Architecture Infrastructure or ad hoc (peer-to-peer)
    Roaming Supports seamless roaming between respective access points (802.11b, 802.11g, 802.11a/b/g, and 802.11a/b/g/Draft-N1)
    Security<ul>
    Authentication WPA6 and WPA26, 802.1X
    Authentication Protocols EAP-TLS, PEAP-TLS, and PEAP-MSCHAPv2
    Encryption 64-bit and 128-bit WEP, AES-CCMP, TKIP (802.11a/b/g only)
    Product Safety UL, C-UL, CB (IEC 60590)
    Video
    Intel created a video to show off how they do their testing on wireless cards, it is included here for your viewing pleasure:<br />
    <object height="350" width="425"><param name="movie" value="http://www.youtube.com/v/aDIsovRjWGk" /><param name="wmode" value="transparent" /><embed height="350" src="http://www.youtube.com/v/aDIsovRjWGk" type="application/x-shockwave-flash" width="425" wmode="transparent" /></object>
  2. Gautam
    Gautam Moderator
    May 21, 2006
    484
    root
    Any word on when manufacturers are going to start offering this?
  3. alphaswift
    Aug 18, 2006
    923
    I've never messed with a wireless network card within a notebook before. Will changing this card be an end-user capable operation?
  4. Tiffany Boggs
    Tiffany Boggs Editor/Site Admin Senior Member
    Nov 24, 2006
    832
    Cincinnati, OH
  5. Gautam
    Gautam Moderator
    May 21, 2006
    484
    root
    I think its a simple mini-PCIe interface. It will work on all notebooks after 2002-03 or so. I would bet that it will work on notebooks with two antenna connections as well (although it has connections for three).
  6. Tiffany Boggs
    Nov 24, 2006
    832
    Cincinnati, OH
    You are right Gautam. According to the documentation it supports 2 or 3 antenna notebooks. :)
