installing window 7 32bit on the tm2
Discussion in 'HP TouchSmart TM2 (Wacom)' started by daslolo, Feb 25, 2010.
  1. daslolo
    daslolo Scribbler - Standard Member
    114
    All the software I use are 32 bits and I think it would be more advantageous to switch back to 32 bits.
    Is it possible (meaning does everything work)
  2. DRTigerlilly
    7,483
    676
    301
    what do you mean does everything work?
  3. daslolo
    114
    I read the usual offenders are difficult to make work on a clean install:
    pressure in photoshop, painter, sketchbook pro
    wireless
    sleep
    bezel button
    (and I may forget a few)
  4. DRTigerlilly
    7,483
    676
    301
    Wireless only relates to x64. The drivers that are in the swsetup folder are for x86
    Sleep is usually related to graphics drivers
    bezel buttons should work once you install the Quick Play buttons software that is in the QLB folder in the SWSETUP folder.
    I honestly expect the x32 install to go better than an x64 install, b/c you don't HAVE to use signed drivers, and shouldn't have as many compatibility issues.
    But you could wait for another user to post about their experience here.
    Be advised going back to x86 you will not be able to utilize more than 3+GB of ram.
  5. daslolo
    114
    Thanks!
    What an utter pain !
    do you know why uninstallin Norton busts pressure in sketchbook and also wireless ?
  6. DRTigerlilly
    7,483
    676
    301
    they probably use common files.
  7. daslolo
    114
    Actually even removing HP Advisor removes pressure in Sketchbook
    Do you know how to restore pressure ?
  8. DRTigerlilly
    7,483
    676
    301
    reinstall the enhanced wacom drivers from their site for tablet pc.
  9. touchytm2
    touchytm2 Pen Pal - Newbie
