Inserting symbols in OneNote
Discussion in 'OneNote, Evernote and Organizers' started by FantasiaWHT, Aug 20, 2007.
  1. FantasiaWHT
    FantasiaWHT Pen Pal - Newbie
    98
    In law school, I use the section and paragraph symbols quite frequently. In Word, the insert-symbol function has an option to create a shortcut key, so I've made Alt-S and Alt-P the shortcut keys for section and paragraph symbols.
    Why doesn't OneNote let you do that? I thought they would have fixed that from OneNote 2003.
    Any easy way around that? I can do the ASCII code instead, but that's time-consuming as well, esp. on a laptop with no numpad.
    Any ideas?
  2. mathiasm
    mathiasm Pen Pal - Newbie
    43
    You may use a little freeware called ClipX (http://www.clipx.org), with its plugin "Stickies".
    So for example, pasting any static text is one shortcut+one key (say Win+v,P), or two clicks plus paste action.
    I find it really handy, although i ever don't buy my Tablet, actually.
