Input panel problem
Discussion in 'Toshiba' started by poetdante, Nov 29, 2005.
  1. ???????
    ??????? Pen Pal - Newbie
    19
    I'm using the Toshiba satellite R10. When I use Microsoft Internet Explorer, there is some options that will appear on the input panel such as www., .com and so on. But when I use Avant browser, I don't get those options anymore. Is there a way to enable it?
  2. Barry J. Doyle
    2,153
    You should see an icon for the TIP (Tablet PC Input Panel) down in your taskbar on the right side. You can activate it any time by tapping on it with the pen.
  3. ???????
    19
    I have no problems activating the TIP. What I cannot do is to activate the extra menu that has www. com and so on.
  4. poetdante
    1,042
    I had a similar problem but after i "broke in" the tablet it worked fine. also, since tablets are made for windows (as in microsoft makes all the operating systems) then of course it will try to promote its own products and make extra features available for Microsoft things. another example is that you can write on msn messenger 7.5.
