Innergie charger
Discussion in 'EP121 Slate' started by fa6ade, Feb 3, 2012.
  1. fa6ade
    fa6ade Pen Pal - Newbie
    88
    My charger broke on monday. I sent it off to Asus to be repaired but I didn't know how long it would take so I bought an Innergie mCube Lite off Maplin.
    Problem is that it doesn't come with the right tip and they aren't responding to my emails. Is there anything I can do?
  2. Steve S
    8,126
    3,636
    <<...Is there anything I can do?..>>
    ...Describe (or, better, provide a clear image of) the adapter tip interface (socket). It would be helpful if you also provided some dimensions...
  3. fa6ade
    88
    Well here's a picture
  4. BlacKnight
    184
    I think the tip is OD 3mm ID 1.3mm. Maplin appear to do one the right size. Maplin order code L44AY. I haven't verified it myself.
  5. fa6ade
    88
    Would buying one of these require me to cut the connector off the end and add it on myself?
  6. BlacKnight
    184
    I thought they were the interchangeable type, but you're right - you'd have to cut the adaptor off the end of the cable and solder the new connector in it's place. Oops, sorry :(
  7. Steve S
    8,126
    3,636
    <<...Well here's a picture...>>
    Update: Still not showing...
  8. Phenomenon
    Phenomenon Pen Pal - Newbie
    49
    Don't email them. Go to their site and in their support section they have a "ask a question" section. Ask that you need an L tip for your EP121 and they will ask you for your device's serial number and address to ship to.
  9. fa6ade
    88
    I'm trying to but every time I click submit it sends me back to the the account info screen even though I've filled everything in.
    Also, there's no option for England or UK on the country.
  10. Phenomenon
    49
    Did you go to your question history and see if it was posted?
