Huion's Kamvas Pro 13
Discussion in 'Artists' started by AvalonX, Aug 29, 2018.
  1. Ondrej
    Ondrej Pen Pal - Newbie
    Hello all! I have recently bought Huion kamvas pro 13 and right from the begginig a i have a problem. While drawing, after few brush strokes the line ¨shoots¨ to the upper right corner of screen. It is making it almost impossible to draw without getting crazy. I have attached a screen of this glitch in attachment. Does anyone else have similar problems? I tryed to find something similar on internet but it seems no one is having my problem. I would be glad for any advice.
  2. CreateNowSleepLater
    CreateNowSleepLater Pen Pal - Newbie
    79
    48
    First thing I would do is make sure there are no other pen display drivers on the device. Second would be to remove devices, reboot and install again. Third, in the driver set all to defaults and do NOT calibrate. There is also a firmward update available that could help. I have a video on my channel about it.
  3. Ondrej
    Hello! Thnks for reply. After many hours of searching the net and testing i found the problem. I have quite old version of Photoshop and that is the problem. I tryed that tablet with my friends computer with the newest photoshop and it works withnout any problems. And on my computer i tryed it with Krita program and there it also works withnout problems. So i have to upgrade my photoshop or start learning with another program :)
    CreateNowSleepLater likes this.
  4. liyuchun
    liyuchun Pen Pal - Newbie
    Huion Kamvas Pro 13 looks really good . I have a Huion 1060 Plus graphics tablet without screen . It gives the largest area (10x6.25 inches) with the most 12 expresskeys and 8192 levels of pen pressure for the lower price.
    I just got the XP-Pen Artist 15.6 Pro ( https://www.xp-pen.com/goods/show/id/394.html ) , it’s my first Screen Drawing tablet . they’ve put out a Pen P05R which is pretty nifty. the Artist 15.6 Pro tablet monitor was pretty pricey . but it’s been worth it so far for me. it also support the pen tilt function just like Huion Kamvas Pro 13 .
  5. doobiedoobiedum
    1,040
    410
    Hope it works really well for you, these are brilliant times for budding digital artists and prices are a lot less than you might think. If you go back 10 years or so your only option would have cost 3 times as much as what you actually paid.
    I did have the Kamvas Pro 13 and I didn't have wobble - but I never saw the promised tilt. Every review I've seen of the new XP-Pen shows tilt working and it works better than my previous experience on older non-screen tablets.
  6. CreateNowSleepLater
    79
    48
    Tilt didn't work at all?
  7. doobiedoobiedum
    1,040
    410
    Nada. I wasn't sure what software it was supported in though - I tried it on the Kamvas connected to my MacBook using Adobe CS6, Medibang and my first copy of Clip Studio.
    I have no idea what software supports tilt on the Kamvas Pro.
  8. CreateNowSleepLater
    79
    48
    Photohshop should. Clip Studio should if the brush supports it. Sounds weird. I dont have a mac but should not be a thing. Maybe that PS is too old? Doubt it though.
  9. doobiedoobiedum
    1,040
    410
    Too late to check now anyway as I sent it back.
    Nice that Huion seem to have fixed the issue of jitter more generally for all users - I remember reading a lot of users who didn't have the issue
