Huawei MateBook Tablet PC Surface Pro 4 Competitor.
Discussion in 'Other Brands' started by alextrela182, Feb 21, 2016.
  1. surfaceproartist
    2,983
    1,910
    I think you'll like the MatePen then. The drag of the tip on the Dell's glass definitely feels closer to a marker than to a ballpoint.
  2. phase IV ending
    phase IV ending Pen Pal - Newbie
    One last thing before I order one:. Do the buttons work? Programmable? Or is it one locked to erase and the other on right click?
  3. DrHelix23
    DrHelix23 Pen Pal - Newbie
    Anyone know where/if you can purchase another charger for the Matebook? It doesn't seem to work with any of my other USB C chargers...
  4. MobileTechReview
    MobileTechReview Scribbler - Standard Member
    266
    313
    Phone USB-C chargers generally won't work with PCs (insufficient output to replace a 45 watt charger). Try the 12" MacBook charger, it works.
    Marty likes this.
  5. jhoff80
    jhoff80 Scribbler - Standard Member Senior Member
    3,220
    924
    Yeah, there's USB-C (5V/3A) and then there's also USB-C Power Delivery (which supports higher voltages).
    Personally, I wouldn't buy the MacBook one, but it's up to you. While it sounds like it'll work for the Matebook, it's kind of limited in that it only does a weird voltage/amperage combination (14.5V, 2A in addition to 5V, 2.4A). For future-proofing with other potential USB-C PD devices you might buy, something more universal might make more sense.
    Google's Universal charger does 5V/3A, 12V/3A, and 20V/3A which should in theory be far more compatible with future devices.
    Innergie also has one that does 5V/3A, 12V/3A, 15V/3A (which I don't know for sure but assume is for MacBook compatibility), and 20V/2.25A (though it is a larger brick than Google's).
    Personally, what I really want is a version of Google's universal charger which has a second 5V/3A port for my phone in addition to its USB-PD port, but I guess it's still too early for that.
  6. alextrela182
    1,429
    552
    Marty and kvoram like this.
  7. kvoram
    885
    784
    I think it is great that bigger pen-abled tablets are planned. While I don't like the Matebook because of that in my opinion horrible keyboard/stand, I hope those bigger ones would be successful so we might get more option in bigger sizes.
  8. Marty
    2,674
    2,036
    surfaceproartist likes this.
  9. alextrela182
    1,429
    552
    JoeS, sonichedgehog360 and dellaster like this.
  10. dellaster
    dellaster Scribbler - Standard Member Senior Member
    1,106
    854
    sonichedgehog360 likes this.
