HP TX2500 cpu upgrade
Discussion in 'Hewlett Packard' started by cool_mike99999, Nov 10, 2009.
  1. cool_mike99999
    cool_mike99999 Pen Pal - Newbie
    hi, this is my first post in this excelent forum, I currently own an hp tx2500 with AMD turion X2 64 bit (RM-70), and my question is, is it worth to upgrade the cpu tp ultra dual core 2.3? or if i increased the ram itt would be better (ram=2gb) running on windows vista
    Thx
  2. TabbedOut
    1,369
    Is it worth it in terms of performance? No, probably not.
    You would probably be better served upgrading to 4gb of RAM and waiting until SSDs drop in price.
  3. koity
    koity Pen Pal - Newbie
    I would recommend to swap CPU after the price drop to an acceptable level.
    Z-87 looks very attractive to me since it has higher HT values.
    I currently use my tx2525ca(RM-70) to play left 4 dead and killing floor :)
  4. 2.0™
    2.0™ Been Inkin' Staff Member
    394
    87
    Bought an OCZ Vertex 60Gb SSD.
    World of difference. Boot time Vista < 1min (to settled desktop).
    With windows 7, boot time is ~30secs.
    Applications "blink" up.
    CPU is ZM-80 (2.1ghz) undervolted using PumaStateCtrl. System runs cool and quiet.
  5. 2.0™
    394
    87
    Not sure this will work. Likely won't since there's no BIOS support for that CPU.
    But nothing beats a failure like a try.
    Even so the Higher HT speed won't make a material difference.
Similar Threads - TX2500 upgrade
  1. Mr. Boosh
    897
