hp TC4200 Battery runtime :(
Discussion in 'Hewlett Packard' started by vsqkaker, Nov 30, 2010.
  1. vsqkaker
    vsqkaker Pen Pal - Newbie
    mine running windows 7 only gets about 40 mins with powersettings way low? what could cause this i tried using something to underclock the processor and that extends it maybe to an hour. I bought it from tigerdirect not too long ago for under 300. Could the battery be at the end of its game? Or am i running something wrong here because all the reviews say almost 5 hours... i dont get anywhere near that. Hope yall can help
  2. fldrice
    fldrice Pen Pal - Newbie
    92
    You probably have an old battery. What kind of usage were you getting under XP Tablet?
  3. mfalderoff
    mfalderoff Pen Pal - Newbie
    Try resetting the battery.
    The easiest way is to reboot and run your machine on safe mode while its UNPLUGGED & let it sit until it shuts itself off (in safe mode, screen saver and other power saving programs/protocols are disabled). Plug it back in and you SHOULD see a difference.
