HP Stream 7 otg cable or adapter?
Discussion in 'Hewlett Packard' started by Cuttysarkkid, Dec 19, 2014.
  1. Cuttysarkkid
    Cuttysarkkid Pen Pal - Newbie
    Anyone have a preference to using a cable OTG plugged into this tablet so there is no quite so much strain on the delicate socket. As opposed to a single one piece adapter which is a more rigid solution. Also is it possible to use the HP supplied cable and add an USB female to USB female adapter on the end to give the same effect?
  2. AspenMan
    AspenMan Pen Pal - Newbie
    Use a flexible cable, it will product less strain on the port. I fried an S4 using a cheap OTG cable too so be carful of that. I'd recommend this on from Amazon: http://www.amazon.com/gp/product/B005GGBYJ4/.
    Good luck! OTG functionality is AWESOME!!!
