HP Stream 7 micro sd card
Discussion in 'Hewlett Packard' started by Dallas Archer, Mar 2, 2015.
  1. Dallas Archer
    Dallas Archer Pen Pal - Newbie
    I noticed that on HP site it says that the Stream 7 can only go up to 32GB micro sd card but I put a 128GB and works fine. But my question is because I have 128GB will it cause problems in the future? Like will my system brake sooner than normal?
  2. Dallas Archer
    Does anyone know if I keep using the 128GB will it cause problems in the future? Or will it be totally ok to use it since it works now?
  3. CF77
    2,303
    did you try to fill up the 128gb and see if you can still access them?
    sometimes, you can only use up to certain gb...but shows 128gb..
    I don't see any long term issue if ir works.​
