HP Split 13 x2 - A closer look
Discussion in 'Hewlett Packard' started by excalibur1814, Nov 15, 2013.
  1. excalibur1814
    2,331
    307
    Hello all,
    I couldn't help myself so I purchased a Split 13 x2 from PC World yesterday and then...
    I decided to destroy it :)
    with this
    A new Plextor M5M mSata 256GB drive and an 8GB DDR3L 1600Mhz ram module (It MUST be a low voltage ram module so DDR'L' not standard DDR).
    Removing the cover wasn't 'that' hard but the amount of strength that has to be used gets a bit worrying. It also helps if you locate the correct maintenance manual. Searching for 'Split x2' presents a pdf with a machine that looks EXACTLY like the Split 13 but the instructions are different and you might end up jabbing a scalpel into the wrong place (Cough). Search for 'HP Split 13' and you'll find the right one. Two screws from the bottom and then, using a scalpel or card, gently lift the silver back cover from the bottom. There's 2 main plastic 'thingies' (What are they called again) holding the cover with a few smaller ones.
    At that point it gets interesting. As soon as you reach the sides you have to use Hulk strength to separate the cover. Once done it's stupidly easy to change the parts. Next.... The keyboard cover will have a 1TB 840 Evo SSD fitted.
    Storage:
    - 256GB Plextor M5M msata SSD (tablet)
    - 64GB MicroSD card (tablet)
    - 1TB Samsung Evo 840 SSD (Keyboard)
    - 128GB SD card (Keyboard)
    The screen is also quite nice.
    Why this machine over all the other available? I already have a Samsung Ativ tab 3 for light use along with a Stylus so, due to the storage options and large screen, I went for this model. It would have been nice if the screen were at least 1600x900 but that's ok as it'll be connected to an external screen.
    Note: PC World, here in the UK, listed it as having the HD 4600 but that is incorrect as it's the 4200! Naughty. I did point that out in the store so it'll be interesting to see if it changes.
    bloodycape, JoeS and jtsmall like this.
  2. leaftye
    4,129
    Well done! I hope whatever tablet I buy in the coming weeks is as easy to upgrade. That'll a big bonus if the way I intend to use it changes.
  3. bloodycape
    2,710
    392
    What made you choose the Split over one of the higher res HP 13in X2 models?
  4. excalibur1814
    2,331
    307
    I'm in the UK and the options are limited. I'd have LOVED to have purchased a 1080p model or Spectre/Envy but they're simply not available. I could import but not having the \ beside z on the keyboard drives me insane (Admin that has to press the \ key a lot).
    I don't think that there's and SD card on the other models either.
  5. bloodycape
    2,710
    392
    I think SD card is on the keyboard, but I think the Envy 13 offers an HDD option in the keyboard either, but that display is suppose to be really something.
  6. excalibur1814
    2,331
    307
    Here's something amusing...
    I'm trying to factory reset the device using the moved recovery partition which, as you know is nothing special, but the recovery restores to the KEYBOARD hard drive (Secondary) and NOT the tablet mSata (Primary).
    Oh, ok, that's ace! :)
  7. atc
    atc Pen Pal - Newbie
    Hi
    I'm in the UK too, where did you buy the RAM from as i would like to upgrade to 8gb ram
    Thanks
    A
  8. excalibur1814
    2,331
    307
    Hello Atc,
    Ebay. Something like auction number: 380774648250
    Mine was 'mac' ram even though it works on other machines.
  9. atc
    Thanks, also is there two slots or one for RAM
  10. excalibur1814
    2,331
    307
    Just one. It's a really nice device (Mine will be on ebay tomorrow as I'm saving again)
