HP Spectre x2 (2017): 12.3" 3000x2000, Kaby-Lake-U+Iris Plus
Discussion in 'Hewlett Packard' started by kvoram, May 22, 2017.
  1. cmd
    cmd Pen Pal - Newbie
    73
    Its looks gunmetal colored (like a very dark grey/silver). I would imagine the 1st gen silver ones are still compatible though
  2. kvoram
    885
    784
    Just to clear up the confusion regarding Thunderbolt: The Spectre x2's USB-C ports do NOT have Thunderbolt 3, nor do the ports show the actual Thunderbolt logo.
    The Thunderbolt logo has a very specific bolt design. It is of course unfortunate that a generic “bolt” is typically also a symbol for electrical power.
    Here is a close-up between the Spectre x2's bolt logo and the official Thunderbolt logo.
    There is also actually an official logo from the USB Implementer’s Forum (USB-IF) that companies should use for labeling a port with USB-Power Delivery but not Thunderbolt. It is a battery-like symbol:
    Here is also a complete overview how the ports should actually be labeled. It just sucks that almost no manufacturer cares about these things. Which is especially annoying with HP as a major member of the USB-IF, since HP employees also co-wrote those exact USB specifications.
  3. MacrosTheBlack007
    MacrosTheBlack007 Scribbler - Standard Member
    143
    In a shock to absolutely no one, HP updated their website and changed the graphics card to the Iris 640.
    kvoram likes this.
  4. cmd
    73
    Finally that's settled. They also charge you twice if you want i7 with 16 GB of RAM right now. That has to be a mistake. (once in the processor selection +$120 from i7 8 GB, and a second time because it says incompatible selection and you must select RAM in separate upgrade +$100).
  5. magnum2107
    magnum2107 Scribbler - Standard Member
    202
    24
    kvoram likes this.
  6. kvoram
    885
    784
    If you do, I hope we hear plenty about your impressions of it :)
  7. MacrosTheBlack007
    143
  8. MacrosTheBlack007
    143
  9. MacrosTheBlack007
    143
  10. MacrosTheBlack007
    143
