HP Pro x2 612 announced - the first HP Business tablet with Wacom technology
Discussion in 'Hewlett Packard' started by HuckleBoo, Jun 4, 2014.
  1. SAM 2013
    859
    221
    The keyboard is only $30 more.
    I wonder what it costs separately?
  2. XJ12
    XJ12 Scribbler - Standard Member
    438
    110
    Recommended choices only state "Pen" for pointing device where configurable tablets have:
    Pointing Device: Wacom Pen and Digitizer to support Wacom Pen
    So what is a "Pen" pointing device? Very specific in a configurable choice, but very ambiguous in the "recommended" configuration.
  3. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,028
    581
    vPro is a marketing term for a bunch of Intel technologies, most importantly AMT which allows side-channel remote access. Most users don't need it, and having it without properly setting it up is a security risk.
  4. ile
    ile Scribbler - Standard Member
    349
    62
    I want this but with
    - Core M Broadwell
    - 13,3" FHD
    - better touchpad without seperate buttons. E. G. a Elantech one
  5. Mesosphere
    5,308
    2,040
    Yep. =)
  6. bilzebub
    bilzebub Pen Pal - Newbie
    77
    Forgive my ignorance, but what is FHD?
    I too will wait for something Broadwellified that can do what my 2740p can
  7. HuckleBoo
    HuckleBoo Pen Pal - Newbie
    84
    Where were you the last .... 10 years? FHD = Full HD = Full High Definition = 1920x1080 pixel resolution. Same as for TV and BluRay.
    The x2 612 will be the successor auf the Spectre x2 and only the $2600 model with the 4302-Y will be comparable with the Core-M 5Y70.
    bilzebub likes this.
  8. bilzebub
    77
    Ha Ha! I've een using my tc4400, 2710p and 2740p, none of which have anything approaching that resolution--thanks for helping. And Yike, I paid 1400 for my last elitebook, 2600 bucks is a fair bit more...
  9. dceggert
    3,094
    536
    I changed my Helix to 1360x768 rsolution. It makes NO SENSE to have 1920x1080 and then set the desktop to 150% scaling factor. It looks just like the lower resolution except the dialog boxes have the OK and CANCEL buttons off the window and unusable with some applications. I set mine to the lower resolution and the scaling factor to 100% and eveythng is as it should be. The new UI 'apps' are unafected.
    If your sole purpose in buying somethng is based on higher and higher numbers then you are destined for disappointment.
  10. bilzebub
    77
    No the resolution is beside the point for me -- I want something lighter with better battery runtime, but it absolutely has to have a pen
