HP Pro x2 612 announced - the first HP Business tablet with Wacom technology
Discussion in 'Hewlett Packard' started by HuckleBoo, Jun 4, 2014.
  1. HuckleBoo
    HuckleBoo Pen Pal - Newbie
    84
    ATIVQ likes this.
  2. HuckleBoo
    84
  3. HuckleBoo
    84
  4. dceggert
    3,122
    565
    Actually, this is a philosophical direction for most of these devices now. You have the TabletPC that can sometimes attach to a keyboard dock, or the Ultrabook with the removable screen. The first is intended to be used as a slate with occasional keyboard use and the latter is intended to be used as a laptop that can be used as a slate occasionally. The Pro X2 612, along with the Q704, Helix, and Surface Pro 3 are of the second category. So, depending on how you intend to use the product would dictate which direction to pick a device from. If you want a slate 80% of the time then this one may not be for you.
  5. SAM 2013
    859
    221
    Beware! If I am reading HPs site correctly:
    It looks like there are models with and WITHOUT the Wacom Digitizer.
    You must order accordingly.
  6. HuckleBoo
    84
    The 612 G1 will be powered by the Core i5 (i3) Haswell technology - I used the HP Spectre x2 (Core i5 Convertible) with an USB-powered AOC display.
    You can daisy chain the display port, like you can do with the Surface Pro. Or you have to plug in an USB3 video adapter for the 3rd screen.
  7. nilum
    nilum Pen Pal - Newbie
    Disassembly Instruction [1][2]
    Configurable Models [1][2]
    Pre-configured Models [1][2]
    Pricing isn't that impressive, but I am sure it will come down once it makes it to retailers.
  8. Mesosphere
    5,319
    2,082
    Hmm... those are pretty smallish batteries for a Haswell device (29 Whr).
  9. magicalUnicorns
    magicalUnicorns Scribbler - Standard Member
    108
    21
    Drawing on slick glass, no.
    Having to put a screen protector on to compensate, no.
    Using the stick barrel pens on market, no.
    OTHERWISE having a larger screen sounds great. But this is a business pc first, so I doubt it will be of any value to the art crowd that are thinking about the Companion.
    Battery pen, eh thats fine, its not that bad, wacom will perfect it if they get into it. It will also break since their latest record has a lot of breaking stuff.
  10. SAM 2013
    859
    221
    Huh, Wacom pens do not use batteries.
    If I understood your post correctly.
