HP Executive Pen
Discussion in 'Hewlett Packard' started by krish, Jun 16, 2013.
  1. krish
    krish Pen Pal - Newbie
    Hi all,
    I have had the chance to use the HP Executive Pen on a HP Revolve 810 for the last week or so.
    I'm running WIndows 8 x64 and the first thing I did was update the firmware & drivers to the latest version from the HP Revolve site (including the May 8 update of the Atmel firmware).
    I must say, the performance of the pen on the laptop leaves a lot to be desired. Ignoring the not so handy part of having to press the pen against the screen to engage it, the pen itself performs so badly in pen-enabled applications like OneNote/Word.
    Palm rejection works sporadically, with often marks being left as a result of the palm or the page zooming in or out.
    But the most disappointing part is how the pen itself works. I mean, I don't have a great handwriting, but the pen absolutely destroyed it. Alphabets in words either half-drawn or completely missing, the pen messes with your handwriting that even attempting to write in a larger handwriting font makes some alphabets appear larger than others.
    I thought it might be me, but I had a chance to try the pen on the Surface Pro and another pen on a Lenovo tablet, and these felt and responded in OneNote & Word so much better. My handwriting was almost as it is on paper, the pen glided across the screen and things appeared to be so much better.
    I am curious as to others' experiences.
    I don't know if the issue is in the pen/digitizer/firmware and I am assuming the Elitepad 900 performs more or less the same as a Revolve 810 - given they use the same digitizer and pen.
    Think HP will attempt to solve this problem? Or is this the best I can expect?
    Regards,
    -krish
    PS: Calibrating the pen made no difference; and calibrating using additional points made the pen more accurate when selecting items on the screen, but had no effect on the issues I mention above.
  2. Bronsky
    8,612
    5,934
    I'm sure Atmel will attempt to improve performance but I would not expect too much. We had similar issues with early versions of the N-Trig hardware on the Slate 500 which were never really corrected by HP or N-Trig.
  3. Rick
    Rick Sr. Manager, Innovation and Experience
    311
    I will contact you offline...Update: If you update your profile to allow receiving private messages, I will send you a message and help you with your pen concerns.
    We will have a new Atmel F/W release out within the next couple weeks. Will keep you posted.
    There is was also a new touch driver released by Microsoft last week.
    Rick
  4. krish
    Hi Rick,
    Thanks for your prompt response. You can send me a private message ... and I definitely appreciate your offer to help out personally.
    I do have the latest Windows Update ... but don't see any Touch Driver in my list of installed programs/Windows Updates.
    Regards,
    -krish
  5. Rick
    311
    Krish, I get a message that states that I can't send you a private message. You may need to have a minimum number of post or something before PM works. You can send an email to HPSlate500@hp.com if you like
    Rick
  6. Steve S
    8,847
    4,628
    <<...I get a message that states that I can't send you a private message...>>
    ...That is correct. Until they reach a post count of 5, all newbies are subject to moderation and restricted privileges (PMs and hotlinks). Member krish still has a little ways to go...
  7. krish
    Hi Rick,
    I just sent you an email to the HPSlate500 address you provided.
    Let's stay in contact about this ... :)
    Regards,
    -krish
  8. invisik
    invisik Pen Pal - Newbie
    Hi,
    I'm also getting about the same results. I did have a Surface Pro for a short time and the HP setup leaves a lot to be desired. My pen's battery dies in about a week or so with only an hour or so of use. I got an Energizer Lithium battery for it today but I may start storing the pen slightly unscrewed so the battery doesn't make contact.
    I will check again this week for more updates and watch this forum for more info.
    Thanks.
    -m
  9. invisik
    FYI I didn't have any updates waiting and I had been storing the pen upside down in my pen holder so the tip wouldn't touch. Thanks.
  10. krish
    I haven't had the chance to test the battery life on the pen.
    I've only had it for a little over a week, and haven't used it intensively - primarily because of the poor experience. It has been a difficult and frustrating path so far ...
    Rick (HP Program Manager) did mention an Atmel firmware update (the digitizer) was in the works and should be out soon.
    So I am curious what kind of improvements that update will bring. We'll find out.
    To be continued ...
    -krish
