HP Elite X2 1012 Discussion Thread
Discussion in 'Hewlett Packard' started by SF6, Dec 27, 2015.
  1. Aitolu
    Aitolu Pen Pal - Newbie
    Hello everyone. I just created this account because I am about to get an X2. I have read all the messages under the thread and they're all insightful.
    Good to know the TB3 port works properly, does the dock charge the tablet? And what other docks can also charge the tablet while having an egpu connected to it.
  2. Aitolu
    Just received my unit today, HP were generous enough to include the usb c dock
    HJK likes this.
  3. lampuiho
    lampuiho Pen Pal - Newbie
    It restored to normal working condition after I replaced the battery and the screen lies flat once again.
  4. Vortex
    Vortex Pen Pal - Newbie
    Just FYI for others' benefit , I ordered the ZeroLemon 20,100 mAh power bank which has a 45 W USB C PD output which supports 12V @ 3 A.
    It's able to charge the x2 easily.
    You just have to hold down the power button so the power bank supplies power to the laptop instead of vice versa
    Also, if you're looking for a cheap hub , the HooToo USB C hub on Amazon works perfectly fine with it.
    HJK likes this.
  5. Aitolu
    Is this normal? My HP usb c dock doesn't work and won't let peripherals be connected unless I plug in the ac adapter.
  6. Aitolu
    Does anyone know how I can contact Hp for a replacement pen? Mine has been giving me headaches since the past couple of days.
  7. Starlight5
    Starlight5 W I N T E R B O R N
    682
    222
    Yes, it only works with psu attached.
    Aitolu likes this.
  8. HJK
    588
    72
    Any other suggestions for portable bricks that play nice with the Elite x2 1012 g1?
  9. HJK
    588
    72
    How much of a charge can you get out of this thing? Let's put it this way, by what percentage does it increase the battery life of your Elite x2?
    Thanks!
  10. Kilted
    Kilted Pen Pal - Newbie
    Yes, I am using a Goal Zero Yeti 100AC. It will support USB-C PD charging my X2 G2 at up to 60 watts out. It also has a Qi wireless charging. Not cheap but it just works, and it is the largest capacity power bank you can carry on board aircraft. https://www.goalzero.com/shop/sherpa-power-banks-and-accessories/sherpa-100ac-power-bank/
    I also have a RavPower 20100mah RP-PB043.
    Both units are high quality, Sherpa 100AC will charge the G2 twice, the RavPower I use to run other USB-C/A devices, it has wired QuickCharge for phone and is great for traveling.
    I will use both on a trip RavPower to keep phone going and Sherpa to keep G2 going.
Similar Threads - Elite 1012 Discussion
  1. Bitech
    966
