HP Compaq EliteBook 2730p : 32 or 64 bit ?
Discussion in 'Software' started by robozo, Apr 14, 2012.
  1. robozo
    robozo Pen Pal - Newbie
    42
    first of all thank you!! i ordered what agent9 recommended :
    HP Compaq EliteBook 2730p Windows 7, Notebook Tablet Dual Core 12" WiFi [51] | eBay
    and it seems it works fine, great service in this forum!!!
    thanks!!
    now i want to install gimp, is my machine 32 or 64 bit?
    greetings robozo
  2. pmatulew
    401
    The hardware can run either version. You'll need to check and see which O.S. is installed.
    Start ->Control Panel -> System
    In the middle of the page it will give you the system specs and what is installed.
  3. Agent 9
    5,376
    I don't know what you want to do in GIMP (drawing, photo editing, text art, ect...), but I've found it very lacking for digital drawing; I know I recommended it in a thread by 'Boots' recently, but if you haven't seen it then I'd recommend you give 'My Paint' a spin (its a nice well featured drawing program that's free opensourced) and the brush engine isn't bad at all
    You will have to be sure you have a recent Wacom Driver installed, Drivers | Wacom Americas
  4. robozo
    42
    mmmh. ok, i guess ill have to check it out, im a illustrator,a drawer, so i want do do digital paintings, airbrush etc.so far gimp seemed allright...
Similar Threads - Compaq EliteBook 2730p
  1. ATIVQ
    23
    7,837
