HP 2730p - No pressure in Gimp
Discussion in 'Software' started by Boots, Apr 12, 2012.
  1. Boots
    Boots Pen Pal - Newbie
    74
    We bought an HP 2730p on Ebay and just received it. It seems to be working well, but we're having trouble enabling pressure sensitivity in Gimp. From what I understand, we should be able to have it detect something so we can enable "screen" but it's not letting us get that far. It says there is nothing to detect.
    It is running Windows 7.
    Help, please?
  2. Agent 9
    5,376
    Go here Drivers | Wacom Americas and install the driver; then reboot and try Gimp again (I don't remember exactly, but I think gimp may have had an option for pressure sensitivity that you have to enable), if pressure doesn't seem to be working then try 'My Paint' (Free, Opensource drawing program that supports pressure and much more).
  3. Boots
    74
    The driver didn't fix the issue with Gimp, but MyPaint is so amazingly responsive we don't even want Gimp anymore, so thank you!
  4. Taikero
    Taikero Pen Pal - Newbie
    27
    Similarly, I am unable to enable pressure sensitivity in Adobe Illustrator using this driver. It works fine in other applications (Photoshop, OneNote), however.
