how to set th modular bay battery as the primary?
Discussion in 'Acer (Gateway)' started by superspypig, Jan 3, 2008.
  1. superspypig
    superspypig Pen Pal - Newbie
    97
    I have been using the6 cell battery in the modular bay while having another 8-cell battery on the back of my c140. This gives me about 8 hours of batter life in class. However, since the whole computer with the 8cell hanging on the back is too big for me to put into my backpack, I havto remove the big battery. But the computer always uses the 6cell modular bay battery first, and after a class or two it is drainged to empty. Then if I would have to keep the 8cell battery on the back to keep my computer sleeping without losing unsaved data.
    I am just wondering, is there a way I can turn the modular bay battery to secondary and the 8cell on the back to primary, so that my computer would use the power in the 8cell batter first?
    Thank you!!
  2. christian15213
    christian15213 Scribbler - Standard Member
    140
    how do you have the DVD drive and mudular battery? That is not possible.
  3. oscarlucy
    oscarlucy Scribbler - Standard Member
    125
    It's called a MODULAR battery for a reason..because it is supposed to go into a modular bay...and a modular bay is one in which it accepts multiple types of drives, batteries, etc....so it is possible to have the DVD drive and modular battery...you simply eject the dvd drive and slide in the modular battery in the modular bay.
  4. nikecar
    1,524
    technally you could have an external USB DVD and use the modular.
  5. christian15213
    140
    true, but having that big of a thing external kinda defeats the purpose?
  6. Oktavius
    Oktavius Pen Pal - Newbie
    18
    Wish I could find a modular battery. :(
    As for the OP, why not try to keep the modular battery out of the unit as much as possible. Like only inserting it when you are going to put it into your backpack.
  7. paranoiaboi
    paranoiaboi Pen Pal - Newbie
    33
    omg i will worship the person who finds this out. cuz i have the same problem.
  8. nikecar
    1,524
    Part numbers for the different modular battery
    QNDAHA63218410
    QND1BTIZZZ00F1
    I've found them, but the sites are iffy and the price is $236.
  9. superspypig
    97
    Ah~ LOL. It seems that this thread had drifted a little bit. anyway. Does anyone know how to solve the original question? P8RSON, I remember found another thread on the forum about the multiple batteries in XP. Do you know anyway I can tweak something in the register to change this priority? after all, discharge the bay battery all the way through too much is pretty bad for it~
  10. superspypig
    97
    I still want to know the answer. I basically messed up my hard drive by repetitively forget to insert the modular bay before I remove the big 8cell battery to put the computer into my backpack, when it is still running~ So painful.
Similar Threads - modular battery primary
  1. ElectronicFur
    14
    1,251
  2. akbeyond
    974
