HOW TO Fix, Mod, your ASUS EP121
Discussion in 'EP121 Slate' started by CF77, Dec 7, 2012.
  1. CF77
    2,303
  2. CF77
    2,303
  3. CF77
    2,303
    HWinfo ...of temp...at full fan...
  4. marcelo2
    marcelo2 Pen Pal - Newbie
    Couldn't one cut one of the cables of what appears to be the CMOS battery, and then soldering the cut cable back to restore the factory BIOS?
    I bricked my ep121 by replacing the BIOS using the BIOS boot software but reading the new BIOS from a NTFS drive.
  5. CF77
    2,303
    there is a sliding switch on side of pcb...possible to enable or disable cmos battery.?
    easier to just disconnect the main battery.. have try to solder the 40 gauge wire?
  6. fgzed
    fgzed Pen Pal - Newbie
    HI
    I have brick my slate too..:mad:
    I think it's dead... but this topic is a very good news for me.I have just 3 questions for Cf77
    -How many for 1 bios chips?
    -Have you solve your chips yourshelf?
    -what's your ep121 still works to this day?
    Thanks a lot and sorry for my english.
  7. CF77
    2,303
    how much is depending on where you are.....from 10 to 30$
    yes...it is working...
  8. CF77
    2,303
    I dropped my Ep121 sideway where the power plug is still connected.
    Result a broken barrel pin..= you can now see the inside positive power connector
    To fix..
    I cut around the adaptor lower, so I can solder the broken barrel...
    cleaned outside..fluxed..and soldered...then expoxy the joint.
  9. datashifter
    datashifter Pen Pal - Newbie
    The text in the image says it all. Hope this helps!
  10. krov
    krov Pen Pal - Newbie
    Hi CF77,
    thanks for post. I've the same problem. In your post, photos are unavailable. Can you refresh them ?
    Best regards from France.
Similar Threads - ASUS EP121
  1. Kumabjorn
    4,176
