How to disable screen orientation hotkeys? (Ctrl-Alt-arrow)
Discussion in 'Lenovo (IBM)' started by paulkon, Jan 2, 2009.
  1. LvsSocer
    LvsSocer Pen Pal - Newbie
    Anyone have any idea how to disable the screen orientation hotkeys on the x61? (Ctrl-Alt-Arrow) I've looked in the BIOS, Keyboard Customizer Utility, and Vista control panel.
    Didn't see it in any, and disabling the customizer has no effect.
    I ask because the Ctrl-Alt-Arrow keys are far more useful mapped to other functions...
    Thanks!
  2. nightcom
    nightcom Pen Pal - Newbie
    28
    Do a CTL + ALT + F12.
    This will bring up the Intel control panel. Goto 'Hot Keys' tab and
    uncheck the box 'Enable Hot Keys'.
  3. paulkon
    paulkon Pen Pal - Newbie
    On a related note, does anybody know how to disable the *other* keyboard shortcut for rotating the screen?
    On the x200 Tablet on the bottom right of the keyboard are the up/down/left/right arrow keys. just above the left/right arrow keys are "rotate left/rotate right" keys, that rotate the screen when pressed with the control key.
    I hit these by mistake sometimes when I just want to do ctrl+left/ctrl+right, and so I want to disable the "rotate left/right" keys.
    The Ctrl+F12 allows disabling the Ctrl+Alt+arrow rotation, but not this other one.
    Any ideas how to disable it?
    thanks,
    Paul.
  4. jonlumpkin
    jonlumpkin Scribbler - Standard Member
    321
    Are you talking about the browser back and forward keys (above left and right arrow respectively)??? I have never had these rotate the screen on the x200. However, if you want to disable them you can use the "Lenovo keyboard customizer utility", you can also set a delay before they are activated if you want to maintain functionality but minimize accidents.
  5. paulkon
    Ahh, now I get it. Yes, it's the browser back and forward keys. When they are used outside of the context of the browser, they just function as "left/right" keys. So when I do Ctrl + [browser back] it looks like Ctrl + left arrow, which rotates the screen left. I do like the ability to quickly rotate the screen, and so I don't want to disable it completely, just in conjunction with the browser forward/back keys.
    So I'll see if I can disable those browser keys using the keyboard customizer--thanks for your help.
