How to activate Bluetooth on a T5010?
Discussion in 'Fujitsu' started by leerraum, Mar 2, 2010.
  1. leerraum
    leerraum Pen Pal - Newbie
    Hi,
    I always had diffuculties to work in the tablet mode with photoshop because I was missing some of my shortcuts. So I thought I could buy a basic bluetooth keyboard and put it next to my t5010.
    But as I tried to figure out if bluetooth works on my system, I experienced some problems. The device manager tells me that bluetooth is activated. When I'm running this bluetooth stack from toshiba and click on the new connection button it tells me bluetooth is not ready. In the options panel of the bluetooth stack tool theres a button which tells me it activates bluetooth. I clicked on it and it told me that I should connect the bluetooth device first.
    Whats going wrong here? any ideas?
    thanks
    leerraum
  2. mmccord
    mmccord Scribbler - Standard Member
    370
    Is your wireless switch turned off? The switch that controls the wifi card also controls the bluetooth function.
  3. leerraum
    nope, wireless is on. I'm just turning it off when I need longer batterie power...
  4. RazzNuts
    507
    have you checked bluetooth device status in the device manager?
  5. leerraum
    yes, I did. It's acivated.
    says: Bluetooth RFCOMM is ready.
  6. chenco
    chenco Pen Pal - Newbie
    I have the same problem with you! Could anyone solve it?
  7. duncanish
    duncanish Pen Pal - Newbie
    18
    hey guys,
    I had a hell of a time working with Bluetooth and T900 ( really little change, I think ) I think it boils down to that weird interplay between Microsoft and Fujitsu's vision of what to dowith your drivers. do you have generic drivers from Microsoft with a generic Bluetooth enumerator?
