How I finally got the Perfect Backup Solution
Discussion in 'Software' started by dmlerner, Sep 5, 2008.
  1. dmlerner
    dmlerner Scribbler - Standard Member
    109
    I've tried things built into Windows, Cobian, TrueCrypt, basically anything attainable for free. They all fell short in some way or another, but I have finally solved the problem.
    Cobian was about as good as it got, but it still took 9 minutes for 200mb of files, which should take less than a minute from HD to SDHC. I finally looked into writing batch files, and it's perfect.
    Copy paste the code below into a text file and save it as whatever you want .bat
    xcopy "C:\Users\David\Documents\*" "D:\Backup\" /Y /E /Q /V /D
    Change C:\etc to the folder you want backed up. Be sure to end in \* .
    Change D:\etc to wherever you want to back up to. Be sure to include the final \
    This will back up only files changed since the last backup (or everything if it is your first run). If you take out /V it will run about 25% faster, but it will not verify the files, so I suggest you leave it. Takes me 26 sec for 213mb from a 7200 RPM HD to a 4gb SDHC in my cardreader, or 21 sec without /V. For a full explanation, please see http://www.ahuka.com/backup/backup3.html to whom I give 95% credit for this post.
    You can then set the file to be run automatically through task scheduler. In Vista, just hit start and type in task scheduler. In XP, I think it's start accessories, system tools, task scheduler, but there might be one more click in there after system tools.
    Vista task scheduler, definitely do advanced options. I was able to have my Backup.bat run every time I lock my computer, aka every time I'm done using it. To just backup the changes I've made in the last day, we're talking like two seconds runtime. A beautiful solution.
    The one thing it doesn't do that I'd like is that it doesn't delete files in the backup that were deleted in the source.
    Good luck and enjoy.
Similar Threads - finally Perfect Backup
  1. doobiedoobiedum
    36
    3,179
  2. Cuberdon75
    1,544
