how do I right click drag with touch?
Discussion in 'Toshiba' started by jrronimo, Sep 4, 2008.
  1. kensuguro
    kensuguro Pen Pal - Newbie
    44
    simple problem.. I want to use mouse gestures for opera, and I need to use right mouse drag.. how do I do that with touch? Or do need to set up some other control?
    Also is there a good theme for use with touch mode? I can change the scroll bars and caption buttons, but still, menu items seem to be too small.. but then i dont' want to loose screen estate by turning down resolution..
  2. kensuguro
    44
    bump.. does anyone know how?
  3. kip2001
    kip2001 Pen Pal - Newbie
    69
    I know on my tx1000 (passive screen only) right-click is a touch and hold (a circle forms around the pointer dot and when it completes the click becomes a right-click).
    -Kip
  4. kensuguro
    44
    problem is, I can right click that way, but can't drag... I'm not sure if it's even possible
  5. kip2001
    69
    thats strange. I was able to do that using mouse gestures in firefox.
  6. WNewquay
    WNewquay Pen Pal - Newbie
    39
    Hi kensugaru,
    On the pen: press and hold the button before you touch the screen.
    Then touch and drag. Does that do what you want?
  7. jrronimo
    jrronimo Pen Pal - Newbie
    For Opera, if you go to opera:config, search for "scroll is pan" and enable it. That makes LEFT click drag, which means you can drag any page all the time.
    The downside is that you can't highlight text wit this since it just wants to scroll. You can still do mouse gestures by tap+hold until the circle is complete and then gesturing.
    You could also probably make a custom button that would turn 'Scroll is Pan' on and off.
Similar Threads - right click drag
  1. KidGalactus
    139
