How Can I Reverse The Order of Messages?
Discussion in 'Site Suggestions and Site Help' started by Steve S, Sep 10, 2014.
  1. Steve S
    8,847
    4,628
    How do I change the display order of messages within a thread (i.e., show newest messages first)?
  2. brubenstein22
    brubenstein22 Scribbler - Standard Member
    143
    34
    I believe this requires an add-on in XenForo (this kind of sorting is not available by default). If this is something that a lot of users want, we can look into implementing it.
  3. Steve S
    8,847
    4,628
    I'd really like to recommend that add-on be installed. Being able to look at newest messages first makes a big difference when you're scanning the forums...
  4. Steve S
    8,847
    4,628
    To The Forum Membership:
    If you want to be able to read your favorite forums from newest to oldest, you need to ask for it! How about a little support for this? Post a +1 !!
  5. ron2k_1
    992
    171
    I use Tapatalk and that's the I view them so I can see why you'd need it on the browser too. So:
    +1
    Swiped from my Galaxy Note 8 using Tapatalk
  6. Kumabjorn
    4,618
    2,953
    +2
  7. jnjroach
    4,164
    1,626
    +1
  8. Mesosphere
    5,320
    2,085
    I always take the link to jump to first unread, so I'm fine without it (and will likely not use it). If this add-on were to be include, would it replace the current behavior, or would it be an option for those that want it?
  9. Steve S
    8,847
    4,628
    <<...would it replace the current behavior, or would it be an option for those that want it?..>>
    ...As I understand it, it would be an option (preference), just as it was on the vBulletin software. You wouldn't have to display it that way if you didn't want to...
  10. Mesosphere
    5,320
    2,085
    Ok, just checking. He mentioned earlier some other settings that don't work that way (like number of posts per page), so I was just checking if this was one of them.
