How can I attach a mouse to my little ASUS Note 8
Discussion in 'Asus' started by michaelws, Apr 20, 2016.
  1. michaelws
    michaelws Scribbler - Standard Member Senior Member
    783
    114
    All it has is the mini usb. Is there a type of mini usb cable that connects to a port or hub with multiple normal USB slots? I know I could use a wireless...but sometimes those don't work properly with some programs I use so I am comfortable and actually prefer wired connections.
    Thanks for any assistance with this.
  2. thierryb
    1,394
    313
    You have to buy a usb otg cable.
  3. Kumabjorn
    4,414
    2,586
    I use a small Bluetooth mouse and it has never failed, I also use a Bluetooth keyboard without problems.
  4. michaelws
    783
    114
    Thanks guys. I have an otc cable. I as looking for one that would have more than a single USB. Would like to attach a keyboard and a mouse...and a flash drive at times.
    I had a bluetooth, a couple of them, one that did not even require the dongle but they had a lapse of a couple of seconds to respond and the dongle-less one had a quirk in it that would cause my 3D program to do something wierd...as though it sent a click-like signal even though I never depressed any buttons on the mouse. I cannot remember exactly what it did, but it made working in that 3D program impossible. I also cannot remember if it was Blender 3D or Zbrush.
    Thanks for the replies and suggestions.
  5. nyb72
    nyb72 Scribbler - Standard Member
    302
    220
    I've seen OTG cables for sale that have multiple ports (usually between 2 to 4). I haven't tried one myself, but I'm assuming it will work as long as the devices don't need a lot of power like a HDD.
  6. michaelws
    783
    114
    Yes...I just found this little one this morning on Amazon. I might give it a try even though it is only USB 2. But it looks like a swiss army knife of otg's. Thanks nyb72
