Hot Keys Not Working
Discussion in 'Asus' started by mercury7, Nov 17, 2006.
  1. mercury7
    mercury7 Pen Pal - Newbie
    Hello,
    For some reason, my "Esc" and "Screen Orientation" hot keys stopped working, however, the "Ctrl*Alt*Del" one still does. Is there any reason you guys know of that would make this happen?
  2. saranya
    saranya Pen Pal - Newbie
    50
    hmmm, not sure since you didn't say if you have vista installed or not. but in general, I think the rotation button depends on if you have the intel graphics software installed.
  3. Loaf.
    137
    check if when you rotate your screen whether or not the screen rotates automatically also. if it doesn't, you have the same "problem" that I do in that if you seem to do anything before all the drivers and software load up when you log in then those hotkeys wont work and the screen wont auto rotate. its really annoying.
  4. mercury7
    I installed the latest Intel graphics driver, and the problem seems to be fixed. Thanks guys!
Similar Threads - Keys Working
  1. Gene Van Horne
    675
  2. Steve S
    610
