High Battery Wear?
Discussion in 'Microsoft' started by jhoff80, Dec 14, 2013.
  1. jhoff80
    3,640
    1,442
    Pretty much overnight on Thursday, my Surface Pro 2 is now showing a full capacity of 22,533 mWh, (out of 42,002 mWh) despite only having a cycle count of 26. (From powercfg /batteryreport) My guess is that the circuitry is just confused about the size of the battery, so yesterday, I tried to drain it until the PC hibernated and then charge it overnight, and that has had no effect on bringing it back where it should be.
    Anyone else know of any solutions for recalibrating the Pro 2 battery? Or seen abnormally high battery wear before?
  2. zhewy
    zhewy Pen Pal - Newbie
    Mine went back to normal by itself at next batteryreport. Others have been finding a reset was needed.
    Try this (for Pro only):
    1. Shut down.
    2. Hold vol + and power button for 15 sec. Surface logo may flash etc. but don't let go for 15 sec.
    3. Let go of both buttons
    4. wait 10 secs.
    5. Press power button to start up.
  3. JoeS
    6,349
    5,140
    Wow, that's terrible. I just checked mine, and it shows 6% battery wear (39.5 Wh capacity out of 42 original) after 28 cycles. Pretty bad as well, no idea how this happened.
  4. jhoff80
    3,640
    1,442
    That did the trick, thank you. It's now back to a much more reasonable 2%.
  5. e-schreiber
    2,629
    59
    Avoid recharging beyond 90%.
    Avoid discharging beyond 10%.
    Avoid recharging before reaching 20% depletion.
    Avoid discharging before reaching 80% charge.
    Perform battery calibration 3-4 times a year in Safe Mode to get around the Standby/Hibernation mechanisms built into the Power Plans.
  6. JoeS
    6,349
    5,140
    But then again, does anyone really stick with these? I violate all of them by mostly keeping the SP2 plugged in. So maybe I deserve that 6% wear..
  7. excalibur1814
    2,455
    503
    I try to ensure that the batteries on my various HP laptops are looked after in case I decide to sell. I don't, however, EVER start to recharge until it literally begs me to recharge at around 4%. So far none of the batteries, when tested using the HP battery check tool, state that the battery life has changed that much or if at all. Maybe some of this is purely... Luck.
  8. DragonGamer
    DragonGamer Pen Pal - Newbie
    61
    Some people over at the surface forums experiecned this drastical drop after the recent firmware update which went wrong.
    MS will hopefully repair that soon...
  9. JoeS
    6,349
    5,140
  10. e-schreiber
    2,629
    59
    I guess keeping it plugged yields no battery depletion, so it shouldn't be a problem.
