Help!!!! Please
Discussion in 'What Tablet PC Should I Buy?' started by P8RSON, Oct 28, 2007.
  1. BFord24
    BFord24 Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    1500-2500
    Convertible
    * Small and light ~ 5" to 8.9"
    * Compact ~ 10"
    * Mainstream ~ 12.1"
    * Large ~ 14"
    Mainstream
    USA
    No...
    writing notes, design, media
    vista ultimate
    photoshop, sketchup, illustrator, itunes, microsoft one note/office
    not really
    Screen Specifics
    widescreen
    * XGA - 1024x768 ~ Large and easy to read text and graphic icons but you fit less on the screen.
    * SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen.
    * WXGA - 1280x768 ~ Wider viewing angle of XGA but ideal for viewing Spreadsheets and other programs that require desktop space.
    wxga
    See explanation below for guidance.
    indoor and outdoor
    active
    wacom
    Component Specifics
    100gig+, 2 gig ddr2 ram
    yes
    maybe, dont like bulky add-ons
    Misc
    stiil not sure what the best pen to use for doing photoshop stuff, need help.
    Intel Centrino Core 2 Duo
  2. carthikv12
    carthikv12 Pen Pal - Newbie
    18
    You should get one with the highest possible resolution if you work on photoshop a lot.
    for 12 inch I suggest you look at the thinkpad series by lenovo or HP. If you can wait, wait for the Dell latitude XT...
  3. P8RSON
    5,189
    Reading your other posts today varthikv12 I notice you are a strong advocate of the not yet released Dell XT.
    Until this Tablet comes to fruit and has been handed out for review, it would be very difficult to recommend this new machine.
    Also bear in mind, this will be Dell's first stab at the Tablet market.... Will they have the ability to pull it off and I don't just mean in sales alone.
    If it were my money and I wanted one with the highest resolution for Photoshop, I would also be looking at a Tablet with strong processing power and bags of RAM (4GB).
    For that my choice would be the Fujitsu T4220 fitted with an SXGA screen and maxed out in both processor and RAM.
    Also consider the Modular battery for additional mobility.
    This would take it to around 7hrs to 9hrs, depending on what you were doing.
Similar Threads - Help Please
  1. Outlineoutlaw
    324
