Help: Pen/touch orientation messed up
Discussion in 'HP TouchSmart TM2 (Wacom)' started by fastangel, Mar 22, 2010.
  1. FxFocus
    FxFocus Ed
    21
    Got the problem back today but with a twist, both pen and touch all over the shop when in ATI mode...
    I noticed that when switching from Intel to ATI the orientation changed 180 so it seems the ATI might be remembering last orientation and be out of sync with Intel.
    So I changed the intel orientation to match the ATI before switching to ATI and that fixed it.
    Seems like certain combinations of changing orientation and switching graphics can both cause and fix the problem...?
  2. Ronzan
    Ronzan Pen Pal - Newbie
    Just experienced the same problem, in tablet mode with ATI, oriented at 180, the pen orientation is messed. When changing to Intel gpu it gets fixed, changing back to ATI and it is messed up again.
    Im using the older version of the hp quick launch thingy to fix the auto rotate problem (http://forum.tabletpcreview.com/showthread.php?t=30452).
    A quick reboot fixed it.
  3. Subliminal
    Subliminal Pen Pal - Newbie
    19
    I had this problem after using the auto rotate problem. I restored to factory settings and the problem goes away and now I just manually rotate the screen. It could be the auto rotate fix that triggers another problem but I'm just speculating.
  4. albysoo
    albysoo Pen Pal - Newbie
    i think i have a solution. go to control panel, tablet PC settings, not to be confused with pen and touch, or pen properties settings.
    select the right screen, then configuration to calibrate pen.
    it worked for me in the ATI, as well as the INTEL GPU
  5. mach5
    mach5 Pen Pal - Newbie
    i had the same problem too yesterday. i just got the newest wacom drivers off the HP support website, installed, and rebooted and everything went back to normal
  6. koao
    koao tm2's great.
    132
    I just had the problem right now.
    I rebooted, and it was fine.
  7. herukuti
    herukuti Pen Pal - Newbie
    22
    is there any way to keep an external monitor from rotating when in tablet mode?
