help, lots of choice but confusing
Discussion in 'What Tablet PC Should I Buy?' started by pibach, Oct 25, 2007.
  1. marcus134
    marcus134 Pen Pal - Newbie
    1. What is your budget?
    less than 2000
    slate or convertible
    Mainstream ~ 12.1" , 1" thick, 3.5 pounds
    Canada maybe US
    not really
    at least 4, ideal 6 or more
    does the active or scalable battery management really improve things?
    school work, note(pdf) editing, spreadsheet
    no
    office or open office or some kind of graphical tablet optimized editor
    diablo 2, civilisation 3 and maybe other medium or low ressource demanding games
    Screen Specifics
    wide
    SXGA - 1400x1050
    WXGA - 1280x768
    Indoor/Outdoor necessary
    active or hybrid
    Wacom, I guess...
    Component Specifics
    60gb, I guess that 2 gb of RAM is a necessity with vista
    could be a slim external one
    could be interesting, but light weight and slim profile before
    Misc
    1. some tablet seems to have enhanced function stylus, like right click or programmable function while others only seems to act as a poiting device, can I have some explanation there?
    2. does the stylus also work in games?
    3. some tablet seems to come with bundled apps that seems to enhance the "tablet experience and usability" while others seems to only come with basic stuff that comes with every laptop, do they worth it? what software could be bought (downloaded) that would do the same thing or better?
    4. I'm looking for something that is light, slim, sturdy, somewhat rugged (water and dust resistance) would be a big plus, for field works once in a while
    I'll buy it during winter, I know things can change a lot since then but, usually, the compagnies are doing their launch and announcement during automn for christmas, so mentionning upcoming models will also interest me.
    PS: english is not my first language, please, don't be harsh on my errors
  2. pibach
    pibach Scribbler - Standard Member
    528
    6) >does the active or scalable battery management really improve things?
    no, not at all. Get something with no software on it. That save you time uninstalling the bloatware ;-)
    HP 2710p or Fujitsu t2010 will meet your demand and can be recommended according to the experience you find here around.
  3. marcus134
    thanks for the answer, whats the difference between vista and xp tablet 2005?
  4. marcus134
    the compaq and the fujitsu seems really nice, does the extra 0.3 (3.6 to 4.0) pounds for the 9 cell battery will make it less comfortable by a lot, for the fujitsu?
  5. pibach
    528
    This is a long debate. Here's my short roundup:
    Vista comes with a lot of new functions - none of which give you anything, imho.
    But there is one important exception, the handwriting recognition!
    You won't go back to XP's handwriting. So forget that.
    But you can buy extra software for it which might be finally the best way. For example Evernote's ritePen is very good handwriting software. And then there is StrokeIt (freeware) you can control everything by gestures. So you do not need Vista, and might be better off with XP as it is less resource hungry.
    But as the above machines come Vista preinstalled and are quite capable if 2GB are installed, you will also live comfortably with Vista.
    regarding battery: I would go with the smaller one since 4-5h is decent and good enough for most situations. If you need more, you can buy another one or the extended one later. It takes a while figuring out what you personally will really need. I, for example, find 2 batteries that you can charge externally extremely valuable since this give you a lot of options and freedom.
    Anyway, check out the various reviews on these machines on this site, people report that weight with the extra battery is nicely balanced.
    The protruding battery on my Thinkpad however is unpleasant and makes the thing heavy and unbalances. But you need that to get 4h runtime.
