Help identifying J3500 part
Discussion in 'Motion Computing' started by DavidDivad, Apr 21, 2017.
  1. DavidDivad
    DavidDivad Pen Pal - Newbie
    Hi I'm trying to find out what these connectors are on a motion computing j3500. It connects the digitizer and display to the tablet motherboard. I've contacted Motion computing but they weren't very helpful. Anyone know the part name and/or compatible cables? Even an LCD connector board would be helpful. Thanks
    [​IMG] [​IMG]
  2. autoperdu
    autoperdu Pen Pal - Newbie
    Are you asking this because your trying to replace screen and digitizer? When I originally received my replacement screen from a vendor on ebay I thought it was not working since I could not get an image, turned out that there is a ribbon cable for the board on the new digitizer/screen that was not well seated, once I re-seated it turned on just fine. Hope this helps.
