HELP for Dell Venue 8 Pro. How to HARD RESET on DELL VENUE 8 PRO
Discussion in 'Dell' started by Kei25, Nov 29, 2013.
  1. Kei25
    Kei25 Pen Pal - Newbie
    Dear all,
    I Just get DELL VENUE 8 PRO TABLET. (Windows 8.1)
    Some how, I had used Calibration touch setting on Control Panel. When in touch calibrate, I have rotate and touch on plus point that required.
    The result so bad. All touch act on screen are miss match position.
    From now on, I cant touch to right position that I want to. So the tablet cant run interface touching is .... huhuhuhuhu
    So my solution is ... hard reset. (I try to hold Power + Windows key to see the boot loader. The result, can go to safe mode for reconfig the touch calibration in control panel)
    Some one help me to fix this BIG PROBLEM???
    Many BIG Thanks and waiting for all your HELP!!!
    Kei
  2. bugelrex
    259
    43
    usb otg cable and a mouse should get you bacj into settings
  3. Kei25
    Thankyou very much. I'll do that way!!!
    Best Regards!
    Kei
  4. binky_rutledge
    binky_rutledge Pen Pal - Newbie
    50
    I'm at a loss for how I got to the restore utilities, I know I got to them from the boot screen but it doesn't seem to be as simple as holding the windows key.
    Hold the Windows key while booting, that gets you to the restore utilities. This utilities screen is unaffected by Windows touchscreen calibration.
    Sent from my XT1055 using Tapatalk
  5. Kei25
  6. mtva24
    mtva24 Pen Pal - Newbie
    Thinking about taking this back. The over-sensitive touchscreen is getting on my last nerves.
  7. JaM
    JaM Pen Pal - Newbie
    please help, how reset a dell venue 8 pro tablet?
