Help, battery won`t charge!! :( What to do?
Discussion in 'EP121 Slate' started by Esp, Aug 11, 2011.
  1. Esp
    Esp Pen Pal - Newbie
    36
    Hello!
    It seems like the battery in my slate won`t charge anymore! :( Last time I used it, some days ago, I had it on until it turned off because of low battery. Everything was normal.
    Now, this evening when I turned it on again, the battery in Windows saids "0% avaible (plugged in, charging)". Problem is, I have charged it for 15 minutes and it`s still at 0%. I tried to turn it off for some minutes and let it charge, but it won`t turn on without the poweradaptor plugged in. :(
    Some days ago, same thing happened, it stayed at 0% when it charged, but it increased to 7% or something when I removed the charger, like a "normal" bug in Windows. Now it`s just dead when I remove the charger.
    Is the battery dead? Nothing to do beside from sending it back to Amazon? Im living in Norway, (Europe) is it possible to send it back to Amazon US from here? I have to pay toll again? (Both for sending it back, AND for taking it into the country again?) :confused:
    I really don`t know what to do right now, would appreciate help so much!!
  2. Esp
    36
    Forgot to say that the LED on the left off the slate is orange, and Windows dosen`t say that the battery needs to be replaced or that it is courrupt or something. When my other computers have had a bad battery, Windows have usually told it to me.
    Btw, my slate is just two months old, (I would say young..) not old enough to die! :(
    Sorry for my bad english, im norwegian. Hope you understand :)
  3. Agent 9
    5,376
    How long did you leave it uncharged for?
    It sounds like you either: [truly] killed the battery, or you tripped the charge/ discharge protect circuit that is built into the EP121. Before doing anything else you should try a battery re-set: shut it down, take the slate apart (there are quick tutorials around showing how to do it, it is easy, and it is unlikely you would damage anything), then you remove the wire connecting the main battery to the motherboard, and let it sit for a few minutes, then plug the battery pack back in and put it back together, then see if it will charge or not
    If not then you will have to either return it, get a replacement, or get a RMA number form ASUS and either get it repaired or replaced by ASUS directly (you may even be able to get them to send you the new unit first, then you send back the defective one; tell them you need the machine and you need to confirm that the new one is working before sending back the defective one)
  4. CF77
    2,303
  5. Esp
    36
    It works!!!
    Before I went to bed yesterday, I put it in to charge som hours in the night, just to see if that could fix the problems before I tried the things mentioned abow here. And guess what - it has now charged to 70%!! So, I think the problem was that it was so completly discharged that it needed to charge for hours just to get over 0%.
    Im so happy it`s working now! :) Just hope I haven`t damaged the battery in any way, leaving it completly discharged for six days?
    Thank you so much for your quick response guys, I really appreciate it! :)
  6. Steve S
    7,179
    2,697
    <<...leaving it completly discharged for six days?..>>
    ...That was really flirting with disaster. You were lucky this time, but if you keep doing this your luck probably won't last too much longer...
  7. kurt_hectic
    kurt_hectic Scribbler - Standard Member
    374
    "<<...leaving it completly discharged for six days?..>>
    ...That was really flirting with disaster."
    If I go for vacations and leave asus for 2 months without charging that will destroy the battery?
    It's a nonsense!
  8. rancher5
    rancher5 Pen Pal - Newbie
    44
    No thats not what he is saying you can leave it alone for a long time but keep a charge in it before you turn it OFF completely, second my inderstanding is if you do shelve it for a while its best to leave it about 80-90% charged, I could be wrong sometimes just ask my wife.
  9. stramec
    stramec Pen Pal - Newbie
    Hi there
    Did you get any resolution to this, mine is doing exactly the same thing!
    Thanks
    Stram
  10. kurt_hectic
    374
