Heat Problem with Fujitsu T4210
Discussion in 'Fujitsu' started by TabletX, Jul 13, 2006.
  1. NewbieX
    NewbieX Pen Pal - Newbie
    It might be within the safety margins, but it's sorta uncomfortable to hold.
    Oh well...
  2. P8RSON
    5,189
    I can understand but being left-handed does help...
    Your hand doesn't catch the part where it's hot.
  3. EvilGenius
    EvilGenius Pen Pal - Newbie
  4. P8RSON
    5,189
    Personally I would not touch any USB controlled cooler.
    1. It draws power from the USB port which in turn uses more processor power, battery juice and raises temperature ~ a bit of a negative use if you see what I mean.
    2. The fans on these devices have an adverse effect as the fan stops cool air from entering the tablet.
  5. onesaint
    onesaint Pen Pal - Newbie
    87
    so p8rson, what temp monitor is it that you use? And is there a capable Fan GUI out there?
  6. PYROTAK
    286
    i looked into this a couple weeks ago and i found out that fujitsu doesn't have a fan speed monitor or something so no, there is no fangui type program for it.
  7. onesaint
    87
    too right. found this http://www.almico.com/speedfan.php which works well. it monitors HDD and 2 other temps but Im not sure what they Correspond to. OH and its free.
  8. PYROTAK
    286
    so can you monitor cpu temps with it?? so that the fans can you know dynamically throttle themselves?
  9. onesaint
    87
    as far as i can tell, ive got the HDD temp (now hitting 50c) and two other temps. there is no way to control the fans that i can tell. and for that matter what the other two readings are. but have a look.
  10. nfwolfpryde
    nfwolfpryde Scribbler - Standard Member
    126
    Just FYI:
    Humidity Range Operating 20 - 85%
    Max Operating Temperature 95 °F
    Min Operating Temperature 41 °F
Similar Threads - Heat Problem Fujitsu
  1. Luca92
    3,354
