having trouble with recovery disc creation
Discussion in 'Hewlett Packard' started by thefinalgamer, Aug 10, 2008.
  1. sas_sas
    sas_sas Pen Pal - Newbie
    25
    Hi,
    I started and managed creating two recovery DVD disks.
    But I am not sure if Disks performed succesfully as Tablet, sometime later, ejected the second DVD disk itself. At first I assumed it is completed and finished but, later it showed it is error so on.
    How can I check out if disks are okay?
    It does not let me to do the same again...
  2. thebranded
    thebranded Pen Pal - Newbie
    92
    i just did a CRC check comparing my original recovery disc to the new ones created via the before mentioned methord. They were different.
    File size was also different (by a few bytes) dunno why. I did you some additonal files in my recovery partition, but much more than a few bytes.
    Have not tested the new discs, so will keep them as a optional backup but make not really trust them.
    [edit]
    sas sas, if it says there was an error i would not trust them. Throw the discs.
    To burn another copy of the discs follow Drtigerlilly's post here http://forum.tabletpcreview.com/showthread.php?t=18581
    i managed to create mine but they were slightly different to the originals. (have not tested them though)
