having trouble with recovery disc creation
Discussion in 'Hewlett Packard' started by thefinalgamer, Aug 10, 2008.
  1. thefinalgamer
    thefinalgamer i miss my tablet
    239
    every time i open the recovery disc creation program it says that i have made recovery discs for the computer already and i haven't. any help?
  2. Crito
    Crito Scribbler - Standard Member
    105
    You're probably SOL. :eek:
  3. DRTigerlilly
    7,476
    672
    301
  4. thefinalgamer
    239
    thanks it worked but now it says that it cant find my recovery partition. the partition is not damaged because i can still restore my system from it and i haven't changed that name of it
  5. DRTigerlilly
    7,476
    672
    301
    thefinalgamer, you were able to burn your recovery disks?
    if you haven't emptied your recycle bin, try restoring the files you deleted.
  6. thefinalgamer
    239
    it wont let me burn my recovery discs and i haven't deleted any files i renamed them
  7. DRTigerlilly
    7,476
    672
    301
    I think by mere virtue of the fact that you found those files it is probably true that recovery disks were burnt once before have you installed sp1?
    I saw some users on the NBR forums mention that after installing sp1 they couldn't make a second set of disks.
  8. thefinalgamer
    239
    i have installed sp1 i guess i am going to have to order the discs from hp
  9. thebranded
    thebranded Pen Pal - Newbie
    92
    What happens if you restore via the recovery partition. It restores Vista without SP1 so you can then burn the new discs following the procedure Drtigerlilly posted to create additional recovery disc's?
    Or does SP1 edit/delete something in the recovery partition?
    I've just tried to create ISO's of my recovery disc but they failed saying CRC errors.
  10. thebranded
    92
    ok only had HPCD.sys in my d: (no where else) renamed it as wellas made a backup) ran the recovery manager and it worked fine!
    rebooted and my recovery partition is still thre and was bootable
