Having Issues with Original Pen
Discussion in 'EP121 Slate' started by bodhijames, Apr 25, 2012.
  1. bodhijames
    bodhijames Pen Pal - Newbie
    Hi All,
    My EP121 started to act nuts on me yesterday. I was using the stock pen and it would think that it was engaged with the screen about a half and inch away. If I was using an app for writing, I could write on the screen without the pen making contact.
    I had a spare that I purchased a while back. Gave it a try and it works perfectly. The stock pen still has the issue.
    Has anyone experienced this before. Any type of battery in the stock pen? Do they have a "shelf life" then just stop working correctly?
    thanks for any input,
    BJ
  2. Steve S
    6,378
    2,053
    <<...The stock pen still has the issue...>>
    bod: Try removing the pen nib and then gently but firmly re-installing it. It sounds like your nib is stuck in the depressed position...
  3. bodhijames
    Hey Steve,
    Thanks for the suggestion. That did the trick!
    BJ
