Hardware of Yore
Discussion in 'Hardware' started by dstrauss, Feb 7, 2017.
  1. dstrauss
    10,795
    9,326
    @sonichedgehog360 - do your homework and be sure you consult some experts before doing anything, especially if they are in the condition you describe. These sound to valuable to rush your sale.
  2. sonichedgehog360
    2,148
    1,719
    Definitely. We will take it slow and easy and consult a reputable appraisal service if we do go ahead and sell any of them.
    thatcomicsguy likes this.
  3. sonichedgehog360
    2,148
    1,719
    I had been wondering for years why NTVDM, the subsystem which allows 16-bit applications to run on 32-bit Windows, was not also available for 64-bit Windows. There was once a DOSBox-like program bearing the title NTVDM64 but it was far from the real deal:
    https://sourceforge.net/projects/nxvdm/
    As of about half a year ago, NTVDM has been finally ported to 64-bit Windows, working on Windows 10 x64, and it is called NTVDMx64. With NTVDMx64, you can now run your favorite 16-bit applications just as you would have in Windows XP and 32-bit versions of Windows. The guide is a bit involved, but the benefits are well worth it. (Should this get taken down, I downloaded a local copy just in case):
    https://github.com/leecher1337/ntvdmx64
    EDIT: Here is a pre-compiled distribution.
    http://olivier.poudade.free.fr/
    http://olivier.poudade.free.fr/arc/MSDOSX64.zip
    Kumabjorn and WillAdams like this.
  4. sonichedgehog360
    2,148
    1,719
    WARNING! It turns out this does not play nice with Creators Update. It completely broke my Command Prompt and PowerShell functionality. After installing it, not even dir or cd would work properly.
  5. Kumabjorn
    4,375
    2,533
    That one is only to run DOS applications, right? Is there anything that lets you run old Windows 16-bit software? The kind you ran on Windows 95 or 98?
    Digital artist found dead in home. Details sketchy.
    sonichedgehog360 likes this.
  6. sonichedgehog360
    2,148
    1,719
    Besides NTVDM, DOSBox (https://www.howtogeek.com/230359/ho...-dosbox-set-up-drivers-and-play-16-bit-games/) or a VM (https://forums.virtualbox.org/viewtopic.php?f=2&t=59559), pretty much.
    The magic of NTVDM in 32-bit Windows is it lets you just double click on a 16-bit program and it runs transparently like any other program normally would. The OS takes care of all the code translation transparently in the background. For games and such, NTVDM is especially convenient.
    GOG (Good Old Games) uses a DOSBox wrapper, I believe, for most of their older games that they sell which have any 16-bit dependencies.
    WillAdams and dellaster like this.
  7. dellaster
    dellaster Scribbler - Standard Member Senior Member
    1,419
    1,262
    They do. The last time (only time) I tried to run one in 64-bit Windows 10, however, I couldn't get it to work. (Master of Orion 2). Maybe they've fixed that by now.
  8. dstrauss
    10,795
    9,326
    Today I want to give full credit to Computerworld for a great review of tech advertising through the ages. Note an example below from the article (those prices are for MB's folks, not GB's or TB's): :eek::eek::eek::eek::eek::eek::eek::eek::eek:
    Marty, sonichedgehog360 and kvoram like this.
  9. kvoram
    880
    784
    So, how many could you guess correctly? I'll allow 2 years +/- deviation to count as correct...
  10. dstrauss
    10,795
    9,326
    The mere fact I was around for most of these is frightening enough...
    Bronsky, dellaster and kvoram like this.
Similar Threads - Hardware Yore
  1. Steve S
    125
    5,109
