Hard reset without the Image recovery (Install.wim) (AsusVivoTabnote8) help
Discussion in 'Asus' started by Nils-san, Jan 28, 2016.
  1. Nils-san
    Nils-san Pen Pal - Newbie
    Hello everyone.
    I need to do a recovery or hard reset to fix some problems. However, i don't the image backup in the SD card that was included (install.wim was it?).
    I have a USB hub, i connected a mouse, a keyboard and an USB with windows 8.1 but it's like it can't detect it.
    What should i do? Thank you.
  2. Akif Kücet
    Akif Kücet Pen Pal - Newbie
  3. Kumabjorn
    4,356
    2,514
    Move it to a USB drive and get an OTG connector.
  4. Nils-san
    I mailed them too, and they always tell me that the only solution is to send back the tablet and put again the "install.wim".
    Yes, i'm using a OGT connector.
    But in the connector i put first the USB hub, then in the hub i place the mouse, the keyboard and a usb drive with win 8.1. I'm using the mouse and the keyboard just in case (if i have to access the bios or the touch doesn't work)
Similar Threads - Hard reset without
  1. T-ravisty
    1,791
