Graphics - C140X
Discussion in 'Acer (Gateway)' started by Nosecandee, Feb 11, 2008.
  1. Nosecandee
    Nosecandee Pen Pal - Newbie
    Hello,
    So I got my c140x with ati 2300 the other day , played some games everything was great. Today when I try to play HL2 with the same settings as last night I get 6-9fps compared to a solid 30fps. I did install a version of direct x last night to play bioshock, I thought that had to be it but I reinstalled the newest version and still getting the same problem.
    Lets see... I also installed the newest sound card driver but other than that no major changes.
    Does anybody know what the problem could be?:confused: :(
  2. ScubaX
    1,011
    What versions of direct x did you install and uninstall?
  3. Nosecandee
    Well I downloaded the auto installer that should install the newest version. The title was Nov.2007 so I am guessing that was the newest version.
  4. icefreez
    icefreez Pen Pal - Newbie
    87
    Make sure you have Vista set on High Performance for power options.
    Also if you are on High Performance and you do not have the power plugged in you will have to Go into the advanced settings for the power option "High Performance" and set the ATI card to run at max performance while on battery. For some reason they thought high performance should truly only be maxed while plugged in :p
  5. chriscannon
    905
    I agree with ice. Sometimes if im not plugged in my computer starts to go pretty slow in more advanced aplications. I usually steer away from high performance because it drains my battery a fair bit, but be sure no matter what to set your graphics card and wireless to the higher settings while on battery. It makes everything much easier. If you want more battery, the graphics card probobly takes more than the wireless.
  6. nikecar
    1,524
    i keep it in high unless I need more battery time, and only when the battery comes down to an hour left will I switch it..
  7. nikotttin
    nikotttin Pen Pal - Newbie
    52
    And in addition you lappie should by plugged in the wall. This sets to graphic card to "high power" and allows smooth playing.
