Going paperless, what should we get?
Discussion in 'What Tablet PC Should I Buy?' started by Miriel, Dec 23, 2012.
  1. Miriel
    Miriel Pen Pal - Newbie
    Hi there!
    My veterinary clinic is going paperless, but not all of our doctors have efficient typing skills. Because of that we're in the market for a tablet with good to excellent handwriting recognition. I used the convertible Toshiba Satellite in vet school and loved it, but Windows 8 has changed the game. I now have no idea what the best option is!
    General Questions.
    1. What is your budget?
    Up to $1200, but the lower the better.
    Yes.
    I'd really prefer something that was in some way convertible.
    10-inches or higher
    Canada/US
    Not really.
    At least 4.
    Note taking/web surfing
    I'd prefer Windows or Droid.
    Open office and cloud/web based clinic software.
    No.
    No.
    Screen Specifics
    None
    2. Will you be using the tablet outdoors? Do you need to be able to see it through glare from the sun? Potentially, but this isn't a frequent scenario.
    Yes. I prefer Wacom.
    Component Specifics
    Expandable is always good. Just needs to be big enough to run basic programs and web surf.
    Prefer full-sized USB/SD.
    Misc
    Will mostly be used sitting in exam rooms, so doesn't have to be featherweight.
    Thanks for your help!
    Miriel
Similar Threads - Going paperless should
  1. 91709jack
    286
