Genius? Or Retarded?
Discussion in 'The Tablet PC Life' started by Shogmaster, Oct 29, 2017.
Act of pure genius or gone full retarded?
  1. You are a rare genius
    4 vote(s)
    80.0%
  2. You are a damn idiot
    1 vote(s)
    20.0%
  1. thatcomicsguy
    3,242
    2,296
    Shoot. I don't even own a set of torx. Just to swap a hard drive? Crazy.
    HP is not user-servicable friendly.
  2. Shogmaster
    4,145
    1,408
    Torx is the just the start of it. They hid a case screw below the DVD drive so unless you opened it you never saw it. Wasted 15 minutes of my life trying to pry that case open because I didnt know about that last hidden screw.
    thatcomicsguy likes this.
  3. Selofain
    Selofain Chronic Lurker
    538
    305
    I don't think it's limited to HP. The last time I was at Best Buy, I saw a lot of torx screws on the bottom of laptops (including the Lenovo Yoga 15), which puzzled me. I hadn't seen torx screws since the days before cell phones were smart phones.
    Honestly, though, better to have torx screws than to be simply glued down.
    thatcomicsguy and Shogmaster like this.
  4. thatcomicsguy
    3,242
    2,296
    :D
    It's a good thing you retained enough adult patience to not just get frustrated and use your manly strength to make things right. I've done my fair share of destructive 'repair' work over the years!
    Starlight5 likes this.
  5. Shogmaster
    4,145
    1,408
    I knew I was going to return it to Best Buy so I was being extra careful, otherwise I was seconds away from going HULK SMASH!!!
    Starlight5 and thatcomicsguy like this.
  6. doobiedoobiedum
    914
    345
    Wow, a 17 inch Wacom screen?
    i'm behind the curve on this thread - what is the model designation? I googled Envy with MPP panel and only this thread pops up.
    Are there any other machines in 17.3 size with the same touchscreen and digitiser?
  7. Shogmaster
    4,145
    1,408
    To be clear this is MPP, not Wacom AES. Using dual protocol Wacom Bamboo Ink shouls not cloud that fact.
    Im not 100% sure but Wacom might offer similar 17.3" AES panel on Lenovo P70/71 still.
    But this HP Envy 17T uses MPP.
    doobiedoobiedum likes this.
  8. thatcomicsguy
    3,242
    2,296
    Hey, did you end up returning it or did you decide to keep it after all?
  9. Shogmaster
    4,145
    1,408
    Found a better deal on the same model at Costco so I returned it at Best Buy but now I coming into holiday budget issues so i might wait until after holidays.
  10. Yogg
    Yogg Pen Pal - Newbie
    You are a rare genius Shogg, You know what I'd like to do though?
    Get ANOTHER screen, like the replacement in the teardown, and remove that pesky keyboard, and replace it with that second screen.:)
    I wonder if these replacement screens are too expensive , I could just get those and build a custom convertible with two screen that fold together.
    Imagine the satisfying feeling as those two panels close together. oh by the great lord crepitus...
    I would settle for two 15.5 s but they'd both have to be pen and touch.
    I'm no tech guru, I would need guidance, or a supertech to make sure the components go together.
    I've searched for mod builders and companies , but never found anyone with the balls to even consider such a task.
    In my mind it's perfectly reasonable, even if I had to use a sneaky display port to get the job done.
    It must be possible.
    Does anyone know of any legit mod masters I could talk to about creating such a demented device?
