Gateway C-140X Battery
Discussion in 'Acer (Gateway)' started by Nosecandee, Feb 8, 2008.
  1. Nosecandee
    Nosecandee Pen Pal - Newbie
    Hey guys just got my new c140x today.
    One thing is bothering me , I only get about 3.5 hours of battery life using a 12 cell battery. Now I heard about people getting 8 hours (using low settings of course). I only surf the net and it lasts me about 3.5 hours with no gaming / dvd viewing. When I click on the battery icon it says that Battery #1 available and Battery # 2 is not available. My guess is that its not reading the 12 cell battery for some reason? Or could it simply be that the person who had this before screwed up the battery?
    Any suggestions would be great!
  2. nikecar
    1,524
    do you have the modular too? if not, and only the 12, battery #1 IS the 12 cell.
    Look in your manual or gateway's support site to recalibrate the battery.
  3. MJCS
    MJCS Pen Pal - Newbie
    80
    I get 5-6 on my 12-cell. Disable the modem, and bluetooth...dim your screen all the way down, set the battery mode (power saving) to power saver
  4. chriscannon
    905
    I get 3-4 hours with normal use on a 6 cell.... try calibrating
  5. leaftye
    4,127
    I think this would be the problem. I assume you're using the wireless nic. Have you noticed how much warmer your computer gets when the wireless is on? That means energy is being used. I bet you'd get another hours if you turned off the wireless, and quite a bit more if you optimized your power settings for battery life. Basically, disable and uninstall everything you're not using, then turn down everything else to the lowest setting you can tolerate.
  6. ScubaX
    1,011
    On my 12 cell I easily got through a 4 hour class last night with 45% showing left when it was done. I had wireless on the entire time and browsed to sites often during class. Including downloading 14 large power points and running several programs. I have not made any adjustments to the power settings - though I did bump the brightness UP a couple.
  7. KingArthur10
    KingArthur10 Pen Pal - Newbie
    83
    With the 8 cell battery, I get about 3.5-4hrs out of my battery with wifi on, bluetooth off, and screen brightness at full. I surf the web, take notes, etc.
Similar Threads - Gateway 140X Battery
  1. rathacat
    807
