Galaxy Note 8- Initial Thoughts and Inking Review
Discussion in 'Samsung Galaxy Note and Tab' started by jl199954, Apr 11, 2013.
  1. jl199954
    jl199954 Scribbler - Standard Member
    150
    46
    On the capacitive pen- there are some coming out- but only the jot script by adonit/ evernote has the truly small tip. I have one ordered, but they are taking their sweet time. Penultimate is okay- used it before with the rubber stylii, but couldn't bear is consistently. I'm still in holding pattern for thinner Surface Pro 3.....or the iPad 13" with stylus.
    Penultimate is owned by Evernote of course.... So hopefully continued deeper integration. I've been using Evernote since it was the continually scrolling sheet you could ink directly in. - I LOVED THAT! There are other note apps you can sync/ send to Evernote.
    Also- Can't Samsung get some better geometry for the camera bump? A device that's rocks (or requires a case not to) just seems poorly planned for writing with.
    I'm hoping the jot script gets me thru to the next great device.
