Full recovery?
Discussion in 'Asus' started by Caldeio, Dec 21, 2014.
  1. Caldeio
    Caldeio Pen Pal - Newbie
    32
    how do I do one? I click the option like in this video.
    But I do it in the bios. Still it does not fully reinstall windows.
    I'm assuming the 64gb model doesn't have the recovery built in and I'm not doing it correctly? These tablet are so different than pc stuff o_O
  2. Caldeio
    32
    Used usb drive to transfer recovery to it. Restart boots, then goes to keyboard layout, then advanced options. It loops.
    Deleted secure keys and secure boot. Same thing. So?
  3. Caldeio
    32
    You need bitlocker turned on, restart with uefi then disable secureboot and the keys. Launch usb, then full reset.
    If you dont know your bitlocker key you can look it up on a website they give.
  4. Caldeio
    32
    So it looks like to do a full recovery you need a usb cd/dvd drive? I cannot figure it out with usb. I searched and searched.
    So since the CDKEY is built into the bios, can I do a new windows install or will that brick my tab?
  5. vvilmos
    vvilmos Pen Pal - Newbie
    The 64GB model has a hidden recovery partition. Have you deleted it?
    If not, then from bios you can Refresh (i.e . without removing files) or Reset (i.e. factory default).
    If you do not have the recovery partition any more, you will need a usb flash with win 8.1. The key is in the bios, you don't need it unless you want to install a "pro" version.
  6. Caldeio
    32
    Yes
    yes, i tried that. But it doesn't do a full recovery. Looks like ill have to reinstall windows
Similar Threads - Full recovery
  1. DRTigerlilly
    934
