Fujitsu T4220 Dust Under Screen after 2 weeks of use
Discussion in 'Fujitsu' started by haplo_09, Sep 16, 2007.
  1. Rieuk
    Rieuk Scribbler - Standard Member
    121
    So you're saying it gets hotter in that region eh... I guess it's possible.
    The other thing I was thinking of is that mic hole there. I wonder if dust is making its way through that. Or perhaps those convenience buttons.
  2. haplo_09
    haplo_09 Pen Pal - Newbie
    48
    Kureshii, what type of tape did you use?
  3. kureshii
    1,478
    Just normal clear tape (the slightly more expensive variety); my screen protector is an overhead projector transparency cut to size (protector on a budget ^_~). It's taped almost all the way round, except at the button panel, graphic LCD and screen clip.
    I doubt it's the mic - looks like there's a sponge filter of sorts already. About the buttons... perhaps. But it looks like they're sealed fairly tight. Perhaps it's time for another disassembly...
    Or maybe we should start issuing screen tape-up advisories =)
  4. Legato86
    Legato86 Pen Pal - Newbie
    73
    I've had my T4220 for about a month and I haven't noticed any build up of dust in my screen whatsoever. I run it for quite a while every day because it is pretty much my desktop replacement. Do you guys mostly run it in tablet or laptop mode?
  5. haplo_09
    48
    how often did you leave your tablet in slate mode overnight.
    I suspect that this could be the reason.
  6. haplo_09
    48
    Hi guys do you know any good tape that doesnt leave adhesive once removed. I am thinking of using it to cover covers, until middle of fall, so i can sent tablet for fixing.
  7. kureshii
    1,478
    I think 3M tape should be good enough, you'll know it when you see it - the roll doesn't pick up dust on its side easily.
  8. Alpha Technogoddess
    Alpha Technogoddess Tablet PC Noob
    52
    Hn.. No dust here on my T2440. I wonder what's up :/ I never get intense heat on my screen though, just on the base and side with the vent.
  9. haplo_09
    48
    that is really strange than. I guess I was unlucky to recieve a defective model :(
